13 years agoThe path from "start_sub_process" to "out_sub" has the constraint applied (40 ns)
I think that all paths from start_sub_process shouldn't have the multicycle constraint applied, because it's a 100MHz signal that goes in a slower process. start_sub_process will be high for 4 periods @ 100MHz to be correctly catched by the multicycled process, but the setup requirement remains 10 ns. Am i wrong? I modified the constraint given by example: set_multicycle_path 4 -from [get_fanouts [get_pins enable_reg|q*] -through [get_pins -hierarchical *|*ena*]] to [get_fanouts [get_pins enable_reg|q*] -through [get_pins -hierarchical *|*ena*]] -end -setup same thing i did for hold requirement. In this way, i hope, only paths from/to enable_reg are multicycled
