AHorn4
8 years agoHow to solve Error (175001): Could not place Channel PLL when trying to use Cyclone V Native PHY IP?
Hi, I am using Quartus II 13.0sp1 (web edition) and Modelsim-Altera 10.1d Starter Edition and am trying to integrate a Cyclone V GX multi-gigabit transceiver into one of my designs. The Cyclone V N...
AHorn4
8 years agoHi Abraham,
Thanks for your response. However, it turns out that the issue is related to trying to use the standard 50MHz clock signal to drive a PLL that also feeds the transceiver. It is a known problem but can be easily fixed with an intermediate clock buffer using ALTCLKCTRL IP core as described here:
Now the design compiles and simulates with no issues.
Cheers
