SPraj4's avatar
SPraj4
7 years ago
How to solve error "174077:on chip termination control block is associated with conflicting I/OS"?
I am trying to design ddr3 interface using Qsys in Quartus Prime Lite Edition for cyclone V GT (5CGTFD9E5F35C7) Development board. While running I/O assignment analysis, I am facing this error. I am not able to understand what causing this error and what should be done in order to solve it .
  • sstrell's avatar
    sstrell
    Did you run the pin_assignments.tcl script generated by the memory IP? This creates the correct I/O assignments for the interface.
    #iwork4intel
  • KennyT_altera's avatar
    KennyT_altera
    Which is correct, you need to run the tcl scripts. Only arria 10 and S10 you do not need to run the tcl scripts.
    • SPraj4's avatar
      SPraj4
      yes I am able to compile it now with 0 errors and some warnings. and working on next step -timing analysis ...but it taking so much time, I facing few setup violations etc.
