8 years agoHow to solve data dependency problem?
After I compiled my kernel,I got the report as following:
Block2: II bottleneck due to data dependency on variable(s): value (kernels.cl:42) Largest critical path contributor(s): 64%: Floating Point Multiply Operation (kernels.cl:83) 36%: Fadd Operation (kernels.cl:83)Block2: code is here:# define NUM 128# define M 512 for(int i=0;i<NUM;i++){ double A[NUM]; double B[NUM]; double Value[M+1]; for(int m=0;m<M;m++){ for (int n=0; n < M - m; n++) { Value[n] =A*value[n] + b*Value[n+1]; } } } There are nested loops and data dependency in the code,How to optimize it?Can anyone give me some advise?Thanks so much3 Replies
Your code does not make much sense to me, it is just overwriting Value[n] and your computation does not depend on "m". Are you sure you are not forgetting a "+" before "="? Furthermore, your inner loop is not pipelineable due to variable exit condition.
"m" is only used in the loop exit condition, and I want to get the final "Value[0]"
Well, either way, your loop on "m" is unpipelineable the way it is. You should either merge the loops on "m" and "n" into one loop, or convert your kernel to NDRange with both "m" and "n" absorbed into the thread dimensions, and let the runtime scheduler handle the job of minimizing the pipeline stalls/bubbles.
