Altera_ForumHonored Contributor11 years agohow to Simulate Nios II with custom component? im new here and my first post, sorry for not being so professional... I successfully simlated Nios II on modelsim using QSYS and Eclipse (run as "nios ii Modelsim"), but when I add my custom comp...Show More
Altera_ForumHonored Contributor11 years agoSorry can you please specifically show me the link for the example you mentioned , thanks.
Recent DiscussionsAutomatically added negative node for TDS output doesn't work with Agilex 5Design Space Explorer - *** Fatal Error: Access Violation at 0X000000001E19EB30Tensor block usageError (169008): Can't turn on open-drain option for differential I/O pin HPS_DDR3_DQS_N[1]Highlight similar instances of a selected word fails when scrollingSolved
