11 years agoHere is the massage I got:
--- Quote Start --- run -a # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - Hello from altera_avalon_mm_master_bfm # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - $Revision:# 1 $ # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - $Date: 2014/02/16 $ # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - AV_ADDRESS_W = 32 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - AV_SYMBOL_W = 8 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - AV_NUMSYMBOLS = 4 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - AV_BURSTCOUNT_W = 3 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - REGISTER_WAITREQUEST = 0 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - AV_FIX_READ_LATENCY = 1 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - AV_MAX_PENDING_READS = 0 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - AV_MAX_PENDING_WRITES = 0 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_READ = 1 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_WRITE = 1 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_ADDRESS = 1 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_BYTE_ENABLE = 1 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_BURSTCOUNT = 0 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_READ_DATA = 1 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_READ_DATA_VALID = 1 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_WRITE_DATA = 1 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_BEGIN_TRANSFER = 0 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_BEGIN_BURST_TRANSFER = 0 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_WAIT_REQUEST = 1 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_LOCK = 0 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_DEBUGACCESS = 0 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_TRANSACTIONID = 0 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_WRITERESPONSE = 0 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_READRESPONSE = 0 # 0: INFO: qsys_system_bfm_master_tb.dut.bfm_master.__hello: - USE_CLKEN = 0 # 0: INFO: ------------------------------------------------------------ --- Quote End --- and then the simulation results: --- Quote Start --- =============================================================== # JTAG-to-Avalon-MM SOPC System Testbench (using the BFM master) # =============================================================== # # 0: verbosity_pkg.set_verbosity: Setting Verbosity level=4 (VERBOSITY_INFO) # * Deassert reset # # ----------------------------------------------- # 1: Test the LEDs. # ----------------------------------------------- # * Write 0xAA to the LEDs # - LED register value = aah # - LED port value = aah # * Walking 1's test # - LED port value = 01h # - LED port value = 02h # - LED port value = 04h # - LED port value = 08h # - LED port value = 10h # - LED port value = 20h # - LED port value = 40h # - LED port value = 80h # # ----------------------------------------------- # 2: Test the push buttons. # ----------------------------------------------- # * Push button value = 55h # * Walking 1's test # - Push button value = 01h # - Push button value = 02h # - Push button value = 04h # - Push button value = 08h # - Push button value = 10h # - Push button value = 20h # - Push button value = 40h # - Push button value = 80h # # ----------------------------------------------- # 3: Test the GCD. # ----------------------------------------------- # * Write 25 to the GCD # 2330000: ERROR: qsys_system_bfm_master_tb.dut.bfm_master.__check_transaction_index: Cycle index 1 exceeds MAX_BURST_SIZE-1 0 # 2330000: FAILURE: verbosity_pkg.abort_simulation: Abort the simulation due to fatal error incident. # ** Note: $finish : ./..//submodules/verbosity_pkg.sv(185) # Time: 2330 ns Iteration: 1 Instance: /qsys_system_bfm_master_tb/dut/bfm_master # 1 # Break in Function abort_simulation at ./..//submodules/verbosity_pkg.sv line 185 --- Quote End ---
