9 years agoHow to simulate NCO using Modelsim
hello, i want to implement a pipeline ADC and I need to use a sine input, i just learned that i can use NCO to generate the waveform, when i compiled in quartus ii, there are errors lik...
9 years agoThen you probably only need the altera_mf.v (Altera Mega Function) library.
How do you know? The datasheet/documentation that comes with the IP or megafunction should identify which libraries are required. However, I'll admit to personally using a more iterative process - trial and error... Cheers, Alex
