14 years agohmm. i was about to point you to the EDA tab of the LPM_CLSHIFT which says it does not require any simulation libraries. looking at the RTL generated by the Wizard, you can see that it instantiates an lpm_clshift module which is part of the LPM or 220model library
the rest is in here: http://www.altera.com/literature/hb/qts/qts_qii53001.pdf
