DKras4
7 years agoHow to simulate ip's generated by the HLS in the Active HDL
Hello, I have a project build in Active HDL. I want to use ip's that is generated by the HLS in this project. Where is the BEH files that should be used by Active HDL? Thanks
KennyT_altera
7 years agoCan you used Modelsim instead? https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls-getting-started.pdf
Currently our user guide show for Modelsim. If you want to use activa HDL, you will have to follow the steps like the modelsim and see if you face any problem using it.
