TPH_zenith
5 years agoHow to simulate IP using Modelsim.
I am new to Quartus Prime Pro 20.1. The last time I used Quartus it was Quartus II 13.1. I generated a dual port ram core and I want to simulate it in Modelsim PE. I generated libraries for modelsim ...
David32
3 years agoI would like to extend the original question to the case where my design uses multiple IP cores.
For a single IP the answer above works fine, however, how to handle the multiple core case?
David
RichardT_altera
3 years agoYou can use the scripted simulation flow or nativelink simulation flow (Quartus Standard version only). Both should works.
For further information, you may checkout the supported simulation flow for Quartus Pro.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
