How to simulate IP using Modelsim.
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
- David323 years ago
I would like to extend the original question to the case where my design uses multiple IP cores.
For a single IP the answer above works fine, however, how to handle the multiple core case?
David
- RichardT_altera3 years ago
You can use the scripted simulation flow or nativelink simulation flow (Quartus Standard version only). Both should works.
For further information, you may checkout the supported simulation flow for Quartus Pro.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
