14 years agohow to setting clock input in test bench module
i need to run my design module at 160kbps ....so i used the clock divider as below:
module clock_divider( master_clk, clk_div ); input master_clk; // 27MHz output reg clk_div; reg [6:0] count; always @ (posedge master_clk) begin if (count > 168) //160kbps begin count <= 0; clk_div <=~clk_div; end else count <= count + 1'b1; end endmodule the problem is how to setting the clock input in the test bench module in order to do the simulation on my design.....can anyone help me?? thanks,
