10 years agohow to set weak pull up resistor
hi, In: assignments - settings - fitter settings - more fitter setting, there is item weak pull-up resistor I set it on and off, i found it does work. But In: assignments - assignment e...
10 years agoDid you make the assignment to a specific pin? Can you post the exact qsf file entry?
