14 years agoWhen using TQ, I can create "Virtual" and "Virtual Generated" clock.
In my opinion, the Virtual Generated clock should be used in set_input_delay/set_output_delay constraints. Because the Virtual clock doesn't have the information on which port the virtual clock binds with, while the Virtual Generated clock does. Should I use "Virtual Generated" clock to do set_input_delay constrain?
