SK_VA
7 years agoHow to set SDC constraints with respect to a clock from pll clock mux inputs?
I have two pll clock muxes.Each of them has two different inputs Outputs from these plls are fed to another mux which selects the input clock to my logic. I want to set max skew,max delay and min d...
GuaBin_N_Intel
Contributor
7 years agoWhat are you trying to constrain? Setting clock frequency at that output of MUX or some sort of routing delay between end points.
