13 years agoQuartus->Tools->License setup
Indicates that you can use the LM_LICENSE_FILE environment variable to point to the license location, though you do not need to set that for the GUI, since you can select the path to the license file. Try setting that variable. The command-line tools should be able to read it, so long as Jenkins inherits the environment correctly. Cheers, Dave
