FvM
3 years agoHow to set HDL_PREFERENCE and MANAGED_FLOW_HDL_PREFERENCE per project
Hello, for automatic generation of .ip files, Quartus is using MANAGED_FLOW_HDL_PREFERENCE setting in quartus2.ini, while platform designer uses HDL_PREFERENCE as default for HDL selection. In Qu...
SyafieqS
3 years agoFrank,
Thanks for your valuable feedback.
I can forward this to the developer and let see what they say.
- FvM3 years ago
thanks for forwarding the question.
To illustrate the problem, if you look at the Board and IP Settings dialog in QPP, the confusing point is that IP related settings are stored differently. While the blue one is stored in .qsf
set_global_assignment -name PROJECT_IP_REGENERATION_POLICY NEVER_REGENERATE_IP
the red one is stored in quartus2.ini
[General 22.4_pro]
HDL_PREFERENCE = VHDL
MANAGED_FLOW_HDL_PREFERENCE = VHDLIn QPS, we at least have the option to rewrite the global setting by a "set_user_option" tcl command, but this doesn't seem to work for QPP. Perhaps someone has already found a solution.
Frank
