How to set dual-purpose pin (nCEO) as regular IO in DSP Builder 18.1?
I have to use dual-purpose pin nCEO as an output pin in my project in DSP Builder. When I tried to compile my project I had such ERROR message
Error (176310): Can't place multiple pins assigned to pin location
Then I have added Quarus Prime Global Project Assignments block from Altlab library with parameters: Assignment name RESERVE_NCEO_AFTER_CONFIGURATION
and Value "Use as regular IO"
And I had the same ERROR message. What am I doing wrong?
Thank you, for your attention.
- CalvinJoaz_P_Intel
Contributor
Hi Dmitri,
Good day.
Kindly refer link below and try the following steps.
Thank you.
- DNEHL
Hi Calvin,
Good day.
I have found the solution. It's correct to set Assignment's name CYCLONEII_RESERVE_NCEO_AFTER_CONFIGURATION
Thank you for your attention.
- DNEHL
HI Calvin,
thanks for the answer, but it doesn't help me.
I'm trying to compile my project in DSP BUILDER in MATLAB, not in Quartus Prime. So I don't have possibility to open assignments menu. I'm using Signal Compiler block for this purpose.
and Value "Use as regular IO". But I had the same ERROR message: Error (176310): Can't place multiple pins assigned to pin location
