DNEHL
7 years agoHow to set dual-purpose pin (nCEO) as regular IO in DSP Builder 18.1?
I have to use dual-purpose pin nCEO as an output pin in my project in DSP Builder. When I tried to compile my project I had such ERROR message Error (176310): Can't place multiple pins assigned to...
DNEHL
7 years agoHI Calvin,
thanks for the answer, but it doesn't help me.
I'm trying to compile my project in DSP BUILDER in MATLAB, not in Quartus Prime. So I don't have possibility to open assignments menu. I'm using Signal Compiler block for this purpose.
Then I have added Quarus Prime Global Project Assignments block from Altlab library with parameters: Assignment name RESERVE_NCEO_AFTER_CONFIGURATION
and Value "Use as regular IO". But I had the same ERROR message: Error (176310): Can't place multiple pins assigned to pin location
