9 years agoHow to see the content of the SDRAM in my DE1-SOC while running (JTAG Altera cable) ?
I have made a simple design in Quartus Prime, in verilog code, not using megawizard, but directly accessing the pins of the SDRAM. I am saving 2 x 16 bits binary numbers on 3 of the 4 banks of the SD...
9 years ago --- Quote Start --- I'm afraid your code won't result in anything being written to the SDRAM. Your state machine doesn't do the right things to control the SDRAM. Have a look, and try to understand, the sdram state diagram on this page (http://www.anandtech.com/show/3851/everything-you-always-wanted-to-know-about-sdram-memory-but-were-afraid-to-ask/3). I hope it gives you an idea of the work involved. How much data to you have to store? Could you make use of the FPGA's internal RAM? Cheers, Alex --- Quote End --- Alex I reduced my data and I'm using the on-chip RAM now, it compiled and loaded to the board, I'm having a unexpected issue though. Data of the third RAM is wrote with 000000000 all the way in. The first 2 RAMS are filled with the right data. I tried this program in the modelsim first, and I'm sure the logic is correct. Do you have any ideas? Also, I wish now to see some kind of report to know the speed of my design to complete the application.
