9 years agoHow to see the content of the SDRAM in my DE1-SOC while running (JTAG Altera cable) ?
I have made a simple design in Quartus Prime, in verilog code, not using megawizard, but directly accessing the pins of the SDRAM. I am saving 2 x 16 bits binary numbers on 3 of the 4 banks of the SD...
9 years agoAlex I don't meant to use the SDRAM for reading, that's why I'm looking the way to "know" the content of the SDRAM. I don't have functionally the need to use the data of the SDRAM, I just want to use it for saving data that my design is being producing cycle by cycle.
For practicing only , I created a simple program as follow module sdram_try (S_DRAM_ADDR, S_DRAM_BA, DRAM_CAS_N, DRAM_CKE, DRAM_CLK, DRAM_CS_N, DRAM_DQ, DRAM_LDQM, DRAM_RAS_N, DRAM_UDQM, DRAM_WE_N, clk, rst_n, LED); input clk; //PIN_AF14 input rst_n; // PIN_AB12 output [12:0] S_DRAM_ADDR; output [1:0] S_DRAM_BA; output DRAM_CAS_N; output DRAM_CKE; output DRAM_CLK; output DRAM_CS_N; output [15:0] DRAM_DQ; output DRAM_LDQM; output DRAM_RAS_N; output DRAM_UDQM; output DRAM_WE_N; output LED; wire [15:0] data_X1, data_X2, data_X3; reg ref_reset, reset_source, sys_clk, enable, save_DRAM_BA, LED, save_DRAM_ADDR; reg DRAM_CAS_N, DRAM_CKE, DRAM_CLK, DRAM_CS_N, DRAM_LDQM, DRAM_RAS_N, DRAM_UDQM, DRAM_WE_N; reg [12:0] DRAM_ADDR,S_DRAM_ADDR; reg [15:0] DRAM_DQ; reg [1:0] DRAM_BA,S_DRAM_BA; reg [2:0] state, nextstate; parameter S0 = 0; parameter S1 = 1; parameter S2 = 2; parameter S3 = 3; parameter S4 = 4; PLL_try PLL_try_inst1 ( .ref_clk_clk (clk), // .ref_reset_reset (ref_reset), // .reset_source_reset (reset_source), // .sdram_clk_clk (DRAM_CLK), // .sys_clk_clk (sys_clk) ); RAM_IN RAM_IN_inst1 ( .data_X1 (data_X1), .data_X2 (data_X2), .data_X3 (data_X3), .indx (S_DRAM_ADDR) ); always @ (posedge clk or negedge rst_n) begin if (~rst_n) begin enable <= 1; state <= S0; S_DRAM_ADDR <= 0; S_DRAM_BA <= 0; end else begin enable <= 0; state <= nextstate; if (save_DRAM_ADDR) begin S_DRAM_ADDR <= DRAM_ADDR; end if (save_DRAM_BA) begin S_DRAM_BA <= DRAM_BA; end //ref_reset <= 1; end end always @ (*) begin DRAM_DQ <= 13'b0000000000000; DRAM_BA <= 2'b00; DRAM_ADDR <= 13'b0000000000000; DRAM_CAS_N <= 1; DRAM_RAS_N <= 1; DRAM_CS_N <= 1; DRAM_CKE <= 1; DRAM_LDQM <= 0; DRAM_UDQM <= 0; DRAM_WE_N <= 1; save_DRAM_BA <= 0; save_DRAM_ADDR <= 0; case (state) S0: begin LED <= 0; if (enable) nextstate <= S1; else nextstate <= S0; end S1: begin LED <= 0; DRAM_DQ <= data_X1; DRAM_BA <= 2'b00; DRAM_WE_N <= 0; save_DRAM_BA <= 1; nextstate <= S2; end S2: begin LED <= 0; DRAM_DQ <= data_X2; DRAM_BA <= 2'b01; DRAM_WE_N <= 0; save_DRAM_BA <= 1; nextstate <= S3; end S3: begin LED <= 0; DRAM_DQ <= data_X3; DRAM_BA <= 2'b10; DRAM_WE_N <= 0; DRAM_ADDR <= S_DRAM_ADDR + 13'b0000000000001; save_DRAM_BA <= 1; save_DRAM_ADDR <= 1; nextstate <= S4; end S4: begin if (S_DRAM_ADDR >= 13'b0000000000011) begin LED <= 1; nextstate = S4; end else begin LED <= 0; nextstate <= S1; end end default: begin DRAM_WE_N <= 1; LED <= 0; nextstate <= S0; end endcase end endmodule I connected the pins, and I can see the LED working, but I ignore if the data is in there. Alex, as for Altera SDRAM IP do you mean the : "SDRAM controller with UNIPHY"?. I'm a little bit confused when generating this controller because it ask me for many signals including a group of "normal" signals and a group of "avalon" signals. The operation seems far more complex than using the RAM. That's why I was intending to use the SDRAM directly, because I think my needs of the SDRAM are quite simpler and I don't need so many control signals.
