Altera_ForumHonored Contributor14 years agoHow to routing mannually between LAB? Hi, All I have encounter a problem when using the CycloneIII EP3C25. There is several high speed signal in design. So I want to routing them mannually and get the ideal transmission prop...Show More
Recent DiscussionsAutomatically added negative node for TDS output doesn't work with Agilex 5Design Space Explorer - *** Fatal Error: Access Violation at 0X000000001E19EB30Tensor block usageError (169008): Can't turn on open-drain option for differential I/O pin HPS_DDR3_DQS_N[1]Highlight similar instances of a selected word fails when scrollingSolved
