10 years agoHow to resolve Path to SOPC Builder directory is not found
I am just starting with Altera OpenCL. I have been able to compile and run some of the example designs. Yesterday I tried using the emulator. After some missing environment variables I got it working. Today I tried some more emulations but whenever I want to compile, either for emulator or for chip I get the message:
aoc: Unable to determine the execution envoronment of the Altera SDK for OpenCL
aoc: Detailed error: Internal error: Path to SOPC Builder directory us not found! I assume I have an enviroment variable wrong, but which one, and how do I find out which it is. I could run checks on all variables but that takes a lot of time. Could you point me to the right variable? Or, if it has another couse, correct me and point me to the correct problem.12 Replies
--- Quote Start --- I am just starting with Altera OpenCL. I have been able to compile and run some of the example designs. Yesterday I tried using the emulator. After some missing environment variables I got it working. Today I tried some more emulations but whenever I want to compile, either for emulator or for chip I get the message:
I assume I have an enviroment variable wrong, but which one, and how do I find out which it is. I could run checks on all variables but that takes a lot of time. Could you point me to the right variable? Or, if it has another couse, correct me and point me to the correct problem. --- Quote End --- Do you solve this problem ?I found the same problem lately?aoc: Unable to determine the execution envoronment of the Altera SDK for OpenCL aoc: Detailed error: Internal error: Path to SOPC Builder directory us not found! - Altera_Forum
Well, if you read through the thread you see how I solved it, or do you have problems after that?
