10 years agoHow to resolve Path to SOPC Builder directory is not found
I am just starting with Altera OpenCL. I have been able to compile and run some of the example designs. Yesterday I tried using the emulator. After some missing environment variables I got it working...
10 years agoI assume you're on windows:
call <path to init_opencl file>/init_opencl.bat
call <path to vcvars64 file>vcvars64.bat and then save this as a .bat file. Then you can run this bat file in your command prompt before running the emulator.
