How to resolve Flex LM failure
We just upgraded our Quartus license from Standard to Pro. The license file is detected, so can open Quartus Pro, but compiles for any Arria 10 part fail - with an error saying: Warning(292000): FLEXlm software error: Version of vendor daemon is too old. and a statement: Error(119013): Current license file does not support the 10AS066H1F34E1HG device. Go to the Self-Service Licensing Center on the Intel FPGA website to manage your licenses (https://mysupport.altera.com/AlteraLicensing/license/index.html).
We have upgraded the license daemon to to Version V11.16.2.1 build 245043 x64_n6. (current version on the Intel website.) but still cannot build with the Arria10 family.
- Vicky1
Which version of Quartus Pro are you using?
'We have upgraded the license daemon to to Version V11.16.2.1 build 245043 x64_n6. ' - - - - since you have upgraded it already it should have worked.
now check the environmental variable setting whether it is pointing to correct version of Quartus Pro?
Vicky
- JHenk3
Hi - thank you for the suggestion. It does not solve the problem. The license is being found. I can open the Quartus version. I can pass analysis and synthesis. It does not fail until the fitter. The failure is the same as noted in the original post above. Thanks. Jen
- JHenk3
I am using Quartus Pro 19.1.0 build 240 03/26/2019.
In case it matters - I do have some older versions of Quartus installed on my PC - to support some of my older products. The oldest one is 12.1sp1. The other versions work, and I can build successfully. (17.0, 18.0, and 12.1). Thanks. Jen
- Vicky1
Hi Jen,
'now check the environmental variable setting whether it is pointing to correct version of Quartus Pro?' ---- Have you confirmed it?
Can you please check uninstalling & reinstalling the Quartus Pro 19.1?
I am looking forward to listen you.
Vicky
- JHenk3
yes, I confirmed the environment variable. We also have multiple PC's all behaving the same way. I will try the uninstall/reinstall again.
- Vicky1
May I know any update?
Vicky
- JHenk3
Hi -
I uninstalled 19.1 and installed 19.2, but it did not fix the failure.
The error is the same:
Thanks, Jen
- JHenk3
Hi - I did reconfirm the path after installation of 19.2. The path is correct, but the fitter still fails.
Jen
- Vicky1
Please '4.4. Configuring the License Manager Server ' from link below,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf
Can you provide the project file (Tool menu-> Archive Project) for replication?
Vicky
- JHenk3
Hi -
Yes we have configured the license server using 4.4 and verified the versions of the alterad daemon and the lmgrd daemon.
They are:
Lmgrd is: lmgrd v11.16.2.1 build 176543 x64_n6 - Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
Alterad is: (alterad) FlexNet Licensing version V11.16.2.1 build 245043 x64_n6
And attached please find the archive for the project I am trying to build.
Of note - another engineer made a different empty project to verify and he got the same failure on his machine.
Jen
- SZack
