KJian6
7 years agoHow to remove the Unused_RX_Clock_Workaround_PMR_CDR_PLL which inserted by Quartus Prime fitter ?
Hi, I have a FPGA system which include both DDR4 IP and USB3 controller. The Quartus prime 18.1 build 222 has inserted lots of Unused_RX_Clock_Workaround_PMR_CDR_PLL during place&route: U...
NurAida_A_Intel
7 years agoDear KJian6,
Based on my understanding, you are referring to “Transmitter PLL” in the GXB Report.
To get rid of these unused PLLs you need to turn OFF the “ENABLE_UNUSED_RX_CLOCK_WORKAROUND ON” in your .QSF as below and re-compile your project.
set_global_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND OFF
set_instance_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND OFF -to <pin name>
After compilation, you should able to see the Total PLLs number decrease and there is no Transmitter PLL generated in your Fitter report.
I sincerely hope this helps.
NAli1
