13 years ago --- Quote Start --- Its unlikely that there are glitches on CK. However, your logic might be incorrect, and you are getting a single FPGA clock of CK high followed by low, followed by high for a larger number of FPGA clocks (or vice versa). You might interpret that as a 'glitch', however, its not, its a pulse that your synchronous logic created. Capture a Signal Tap II logic analyzer trace of CK and look at the signal with an oscilloscope. Cheers, Dave --- Quote End --- Yes, Dave, you are right. Actually, there is no glitches appear in simulation after I changed my code as I posted. The question I ask is I just assume there are still glitches. As you mentioned, now I understand is: if I make my design as I posted, in this case, there should not be any more glitches.
