13 years ago --- Quote Start --- If I replace the combinational logic output to register output like: always @(posedge clk_fast) begin if (counterScan>14 && counterScan<31) CK<=clk_200ns; else CK<=0 end but there are still glitches, what should I do to remove the glitch? --- Quote End --- Its unlikely that there are glitches on CK. However, your logic might be incorrect, and you are getting a single FPGA clock of CK high followed by low, followed by high for a larger number of FPGA clocks (or vice versa). You might interpret that as a 'glitch', however, its not, its a pulse that your synchronous logic created. Capture a Signal Tap II logic analyzer trace of CK and look at the signal with an oscilloscope. Cheers, Dave
