13 years ago --- Quote Start --- Besides other signals, you are creating CK as a gated clock from clk_200 ns. Without discussing the general timing problems brought up by gated or generated clocks, I see two options to do it in a proper synchronous way: - have a higher system clock, at least 100 ns period. This won't be a problem unless the 5 MHz clock is your primary input clock - refer to the gated clock design suggested in the Quartus software handbook. It uses a register clocked at the negative edge to delay the gate signal. --- Quote End --- Thanks very much. I think the 1st option you mentioned is I have posted. Is replacing the combinational logic gated clock with register gated clock a general approach to avoid the glitch? And do you mean the " Quartus software handbook" is the pdf file I can download from the Altera website? Thanks again.
