8 years agoHow to reduce the use of RAM blocks?
Hi, After I compile my OpenCL FPGA code, the use of RAM(memory) bits is 40%, but the use of RAM(memory) blocks is 75%, how to reduce the use of memory blocks? Thanks!
8 years agoDecrease the number of accesses to your local memory buffers. You can also use the guidelines available in "Intel FPGA SDK for OpenCL Best Practices Guide, Section 7.4-7.5".
