--- Quote Start ---
If I have a block of memory initialized by an instance of lpm_ram_dq.
// instantiating lpm_ram_dq
lpm_ram_dq ram (.data(datain), .address(addr), .we(we), .inclock(inclk), .outclock(outclk), .q(dataout));
If I want to read out data at "addr (e.g. addr = 2)" to an output variable outdata using nonblocking assignment, how should do it? Is there a similar format like "outdata <= mem[2]" or "assign outdata = mem[2]"?
--- Quote End ---
In case if you havent solved the above problem, here is my suggestion. I believe you instantiate the lpm_ram_dq in a custom module, for e.g. as in the following code fragment:
module LPM_RAM_DQ_1024_16_DM (din, dout, addr, clk, wr, outdata);
parameter width = 16;
parameter depth = 10;
input clk, wr;
input [depth-1:0] addr;
input [width-1:0] din;
output [width-1:0] dout, outdata;
wire high;
assign high = 1;
lpm_ram_dq myRAM (.data(din),
.q(dout),
.address(addr),
.we(wr),
.inclock(clk),
.outclock(high));
defparam myRAM.lpm_width = width;
defparam myRAM.lpm_widthad = depth; // 2^10 = 1024 addresses
defparam myRAM.lpm_indata = "REGISTERED";
defparam myRAM.lpm_outdata = "UNREGISTERED";
defparam myRAM.lpm_file = "RAM_1024_16bits.mif";
assign outdata = dout;
endmodule
i.e. use the assign statement to point your outdata output to the lpm_ram_dq .q output
