SDe_J
7 years agoHow to properly set up a stratix 10 transceiver in Quartus 17.1
Hello, I'm trying to implement an l-tile transceiver in Quartus 17.1. I have implemented the transceiver with the PCS direct setting, as I have custom fpga code for decoding. I have implemented t...
SDe_J
7 years agoEvidently the manual I looked at was for the wrong device. It turns out the pins I has assigned were not correct. I looked at an example design and was able to find the correct pins.
