how to program hex file of a NIOS II project addional in bitstream programming process?
I want to add the .hex output file of a simple NIOS II project into the download process of the bitstream in quartus. I already added the .qip file (necessary for memory initialization) to my quartus project. But the software isn't processed after programming. Programming and running the software via JTAG-UART works.
I am using the Quartus Prime Lite Edtion 18.0. with the DEO-NANO development board (CYCLONE IV EP4CE22F17C6N as on board FPGA).
So what can be the reason for my problem? What do I have to add in my development process? What do I forget?
Best regards Florian
- JOHI
Contributor
Add a rom memory component to your .Qys platform and use the .hex as an initialization file for the component.
Be careful not to use licensed IP in your configuration.
Johi.
- FMutt1
thank you for your answer. I added a ROM but it didn't worked. Do I have to add a BOOT Copier at my software and if yes how?
Flo
- Ahmed_H_Intel1
Hi, Here you can find the required info about the NIOS II boot copier. Please check: https://www.intel.com/content/www/us/en/programmable/documentation/lro1432739743862.html#lro1432740750432 Regards, - Ahmed_H_Intel1
Hi, Do you see this info sent before is useful? Regards.
