FMutt1
7 years agohow to program hex file of a NIOS II project addional in bitstream programming process?
Hello, I want to add the .hex output file of a simple NIOS II project into the download process of the bitstream in quartus. I already added the .qip file (necessary for memory initialization) to m...
JOHI
Contributor
7 years agoHello,
Add a rom memory component to your .Qys platform and use the .hex as an initialization file for the component.
Be careful not to use licensed IP in your configuration.
Johi.
- FMutt17 years ago
thank you for your answer. I added a ROM but it didn't worked. Do I have to add a BOOT Copier at my software and if yes how?
Flo
