You can probe the deserializer parallel output.
--- Quote Start --- You can probe the deserializer parallel output. --- Quote End --- Thank you very much! - Altera_Forum
--- Quote Start --- Also I can't place an output pin at the output of the lvdx_rx --- Quote End --- You mean, you don't know how to place and connect outputs for a bus in schematic design? The problem isn't related to LVDS_RX, I think. Without connecting in- and outputs, your design won't be synthesized and can't be probed in simulation. - Altera_Forum
--- Quote Start --- You mean, you don't know how to place and connect outputs for a bus in schematic design? The problem isn't related to LVDS_RX, I think. Without connecting in- and outputs, your design won't be synthesized and can't be probed in simulation. --- Quote End --- I am sorry for my unclear discription. In fact I can place the output pin at the output of the lvdx_rx for a bus in the schematic design. But What I want to say is that when I place the output pin at the output of the lvdx_rx the compiler is not successful in Quartus II 9.1 SP 2. I wonder it is the problem of Quartus II. So I want to update Quartus II to have a try. Could you please give me some advice ? Thank you very much for you reply.
