How to print Counter output in NIOS console ?
I have followed this topic Simulating Designs with Lower-Level Qsys Systems as example design.
But i want to read the counter incremented data in NIOS console. Please suggest me , how .
Shall i add PIO- 8-bit output in SOPC builder and whether it can be possible to read ? ?
- a_x_h_75
Contributor
Yes - you can add another PIO - configured as an input - and connect your 'count'' output signal to it. You can then use an 'IORD' instruction to read the value of the port.
Cheers,
Alex
- SS5
Thanks for your response.
Please check my NIOS_code. Without FOR LOOP, how should i run the counter module.
#include "sys/alt_stdio.h" #include "alt_types.h" #include<io.h> #include<system.h> #include<stdio.h> int main() { int result,i; IOWR(ENABLE_BASE, 0, 0x0); // Enable the counter alt_printf("Hello from Nios II!\n"); // Send Hello World to the JTAG UART usleep(100); for (i=0;i<10000;i++) { result=IORD(COUNTER_OUT_BASE, 0); printf("%d\n",(result+i)); } // IOWR(ENABLE_BASE, 0, 0x1); return 0; } - SS5
I am not sure whether my design flow is right ?
Please suggest me
module counter ///SUB ( input clk, enable, rst_n, output reg[7:0] count ); always @ (posedge clk or negedge rst_n) begin if (~rst_n) count <= 0; else if (enable == 1'b1) count <= count + 1; end endmodulemodule Counter_Top_Level_design ///TOP ( input clk, input rst_n, output [7:0] out ); wire counter_enable; counter counter_inst ( .clk ( clk ), .rst_n ( rst_n ), .enable ( counter_enable ), .count ( out ) ); // For simulation, use this instantiation: NIOS_SYSTEM niosii_system_inst ( .clk_clk ( clk ), // clk.clk .reset_reset_n ( rst_n ), // reset.reset_n .enable_external_connection_export ( counter_enable ), // output_pio.export .cout_export ( count ) ); endmoduleNIOS
int result,i; IOWR(ENABLE_BASE, 0, 0x0); // Enable the counter alt_printf("Hello from Nios II!\n"); // Send Hello World to the JTAG UART usleep(100); for (i=0;i<10000;i++) { result=IORD(COUNTER_OUT_BASE, 0); printf("%d\n",(result+i)); } - a_x_h_75
Contributor
Your connection to 'cout_export' should be 'out', not count which doesn't exist in 'Counter_Top_Level_design' (only in 'counter').
As for the Nios code - it looks fine.
>>""Without FOR LOOP, how should i run the counter module.""
Without knowing what you're trying to do I don't know what to suggest.
Cheers,
Alex
- SS5
Sorry :)
As per your instruction i have modified the code.
How to justify counter design is working or not ?
I have attached the screenshot in that only FOR loop is increaming ,
- SS5
Design FLOW :From Quartus, i want to read the counter data in NIOS through QSYS.
- Giving Enable signal as PIO output -1-bit
- Reading Counter Data as PIO INPUT -8 bit
Please go through from the starting .
- a_x_h_75
Contributor
This is DISABLING the counter, not enabling it. Your verilog code has an active LOW reset in the counter module.
Cheers,
Alex
- SS5
- a_x_h_75
Contributor
Are you expecting too much from printf? It's a VERY slow function and I can quite imagine 1000's of clock cycles happening between each of your IORD instructions.
Cheers,
Alex
- SS5
I am stuck in this task for Past one week. Please tell me the Solution how to sort it out., as i am New to Altera Quartus.
Any Memories blaock will work it out like FIFO, SDRAM etc.
