APras18's avatar
APras18
7 years ago
How to package a custom IP containing IP as submodule
I have created simple design where I instantiate LPM_sub_add IP as submodule. I would like to package the whole top level so that I can reuse IP. Below are the steps used:
  1. Create a new component in Platform designer.
  2. I added the .qip file of the IP along with top VHDL file in the synthesis files.
While generating the complete IP I am seeing bunch of errors:
Error: Component add1 can't instantiate a custom component with the same name as itself
Error: add1.add1_0.add1_0: Component add1 1.0 not found or could not be instantiated
Error: add1.clk_0.clk/add1_0.clock: Missing connection end (try "Remove Dangling Connections")
Error: add1.add1_0: add1_0.clk must be connected to a clock output
Error: add1_0: missing_module does not support generation.
Error: qsys-generate failed with exit code 1: 4 Errors, 3 Warnings
I guess somehow I have to stitch the netlsit but not sure though. I am not sure if I am missing something basic here. Can someone please guide me with the exact steps to package a custom IP which has submodule IPs?
