APras18
7 years agoHow to package a custom IP containing IP as submodule
Hi, I have created simple design where I instantiate LPM_sub_add IP as submodule. I would like to package the whole top level so that I can reuse IP. Below are the steps used: Create a new compone...
APras18
6 years ago@KennyT_Intel let me elaborate the issue. I have attached a simple test case where I have instantiated LPM_sub_add IP. I want to package the entire led_comp module. It means I have to package the entire system which includes the IP.
According to your reply, I think I should add the Tcl command in hw.tcl. However, I am confused, how can I pass information regarding port map. Can you please provide elaborate steps on how to proceed for the same. My actual implementation is on a big project. If you can guide me for this simple testcase, then that will provide me reference for the main design. Thanks for your help in advance.
Do you have service portal where I can raise a request?
