8 years agoHow to not assign outputs to any pins and avoid being optimized out
Hello, Is it a must to assign outputs of circuit to pins in FPGA? I have a ASIC design of an AES cipher that I want to test on FPGA, but I don't really want to connect the outputs of the circuit t...
8 years agoHow do you intend to test your design on an FPGA if you don't assign the outputs to anything?
Quartus will only remove bits of the circuit which will have no affect (e.g. unconnected outputs).
