10 years agoHow to move the Qsys folder
Hi, I want to move the Qsys folder to a new position. What else do I need to change after moving/renaming the folder? I tried this before, but got an error in Quartus. Thanks for you...
10 years ago@ted: Thanks for the suggestion.
I have changed the path to the .qip and it seems to work ... But I get the following errors if I try to generate the system by Qsys:Error: soc_system.intr_capturer_0: Component intr_capturer 100.99.98.97 not found or could not be instantiated
Error: soc_system.avs_to_wbs_bridge_0: Component avs_to_wbs_bridge 1.0 not found or could not be instantiated:confused:
