10 years agoHow to move the Qsys folder
Hi, I want to move the Qsys folder to a new position. What else do I need to change after moving/renaming the folder? I tried this before, but got an error in Quartus. Thanks for you...
10 years agoYou probably just need to delete, re-add the .qip file. Or edit your .qsf file directly and change the path.
FYI, instead of using Qsys to generate the files and adding the .qip to your Quartus project, you can also just add the .qsys file directly to your project. Then when you compile your project, Qsys will automatically generate the Qsys system.
