9 years agoHow to merge two or more buses?
I'm sorry for asking what it is probably a silly question, but i'm having trouble trying to merge 3 buses(2 buses containing 5 bits(0..4), 1 bus containing 16 bits(0..15) into one bus containing 26 b...
9 years agoYou could try using signaltap to check things in your design.
But in the long run, you will be much better served using HDL (VHDL or Verilog) instead of schematics. They allow you to perform simulations, check code into version control and migrate your code to other vendors products.
