9 years agoHow to merge two or more buses?
I'm sorry for asking what it is probably a silly question, but i'm having trouble trying to merge 3 buses(2 buses containing 5 bits(0..4), 1 bus containing 16 bits(0..15) into one bus containing 26 b...
9 years ago --- Quote Start --- Disconnect the busses and use named association to link them. Label them shifter[0..15], shifter[16..20] and shifter[21..25] The fact they now have the same name will link them together when its compiled --- Quote End --- thanks Tricky, i got it! One more doubt, if i'm allowed to ask in this same topic. I compiled my circuit and now i need to be able to check the values that are inside my registers during the execution. It seems that i can only check output pins and that may not be enough...
