Altera_ForumHonored Contributor12 years agoHow to measure the clock cycles used in a program in quartus? Hello How to measure the clock cycles used in a program in quartus? or the latency time of the program.
Altera_ForumHonored Contributor12 years agoQuartis doesn't run any programs. It compiles your code into a netlist.
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
