Chris039
3 years agoHow to make sure clocks are in phase?
I have two clock sources, both with 100Mhz. How to make sure that the clock are in phase?
Data from register A with clock A to register B with clock B.
Do I need to set any SDC or Quart...
- 3 years ago
Best way is to source both clocks from the same PLL. You don't say where these clocks are coming from. Feed one into a PLL and then create two mirrored outputs.
Nurina
3 years agoHi,
Are these clocks coming from 2 different sources outside the FPGA?
You could use set_clock_latency if you know what is the additional delay: https://www.intel.com/content/www/us/en/docs/programmable/683243/21-3/set-clock-latency-set-clock-latency.html
If the clocks are sourced from the FPGA, I don't think you can use sdc constraints, you would need them to come from the same source. As mentioned in the above comment, best way is to source both clocks with a PLL.
Nurina
