Chris039
3 years agoHow to make sure clocks are in phase?
I have two clock sources, both with 100Mhz. How to make sure that the clock are in phase?
Data from register A with clock A to register B with clock B.
Do I need to set any SDC or Quart...
- 3 years ago
Best way is to source both clocks from the same PLL. You don't say where these clocks are coming from. Feed one into a PLL and then create two mirrored outputs.
sstrell
3 years agocreate_clock constraint on the 100 MHz input, created_generated_clock on the 125MHz clock. I'm not sure what you mean about latching data a few cycles later. That isn't part of defining the timing constraints for clocks.
