12 years ago --- Quote Start --- Yup, write a testbench and get simulating. But you dont really specify exactly what you want? what exactly are you averaging? Notes on your code: - You dont show the whole code, so we cannot see signal declarations - WHy have you got a for loop summing together things? - This code looks messy A moving window average is easily acheived with a shift register and an adder tree, with a divider on the end. If the window is 2^n wide, all you need to divide is drop the n LSBs (with a possible rounding stage) --- Quote End --- I didn't show the whole code because it's very long.This code is writen by others and I just want to know what exactly it work and use it in my work. I have writen a copy for simulation. I will put it below. library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use ieee.std_logic_unsigned.all; entity Averager is port(CLK80: in std_logic; sigCReg: in signed(13 downto 0); SigSReg: in signed(13 downto 0); samplingTriggerReg: in std_logic; sigCLatchReg: in std_logic; sigSLatchReg: in std_logic; dfTrigSReg :out std_logic ; dftrigCReg: out std_logic; WS0: out signed(17 downto 0); WS1: out signed(17 downto 0); WS2: out signed(17 downto 0); WS3: out signed(17 downto 0); WS4: out signed(17 downto 0); WS5: out signed(17 downto 0); WS6: out signed(17 downto 0); WS7: out signed(17 downto 0); WS8: out signed(17 downto 0); WS9: out signed(17 downto 0) ); end Averager; architecture Behavioral of Averager is signal avCStateReg, avSStateReg: std_logic_vector(4 downto 0):="00000"; type avSig is array (0 to 9) of signed(17 downto 0); signal avSigSReg,avSigCReg: avSig; begin process(CLK80) begin if(CLK80'event and CLK80='1') then if(samplingTriggerReg='1') then -- synchronization with the sampling trigger avCStateReg <= "00000"; else case avCStateReg is when "00000"=> if(sigCLatchReg='1') then avCStateReg<="00001"; end if; when "00001"=> if(sigCLatchReg='1') then avCStateReg<="00011"; end if; when "00011"=> if(sigCLatchReg='1') then avCStateReg<="00111"; end if; when "00111"=> if(sigCLatchReg='1') then avCStateReg<="01111"; end if; when "01111"=> if(sigCLatchReg='1') then avCStateReg<="11111"; end if; when "11111"=> if(sigCLatchReg='1') then avCStateReg<="11110"; end if; when "11110"=> if(sigCLatchReg='1') then avCStateReg<="11100"; end if; when "11100"=> if(sigCLatchReg='1') then avCStateReg<="11000"; end if; when "11000"=> if(sigCLatchReg='1') then avCStateReg<="10000"; end if; when "10000"=> if(sigCLatchReg='1') then avCStateReg<="00000"; end if; when others => avCStateReg<="00000"; end case; end if; end if; end process; dfTrigCReg <= '1' when avCStateReg="10000" else '0'; process(CLK80) begin if(CLK80'event and CLK80='1') then if(samplingTriggerReg='1') then -- synchronization with the sampling trigger avSStateReg <= "00000"; else case avSStateReg is --gray counter? when "00000"=> if(sigSLatchReg='1') then avSStateReg<="00001"; end if; when "00001"=> if(sigSLatchReg='1') then avSStateReg<="00011"; end if; when "00011"=> if(sigSLatchReg='1') then avSStateReg<="00111"; end if; when "00111"=> if(sigSLatchReg='1') then avSStateReg<="01111"; end if; when "01111"=> if(sigSLatchReg='1') then avSStateReg<="11111"; end if; when "11111"=> if(sigSLatchReg='1') then avSStateReg<="11110"; end if; when "11110"=> if(sigSLatchReg='1') then avSStateReg<="11100"; end if; when "11100"=> if(sigSLatchReg='1') then avSStateReg<="11000"; end if; when "11000"=> if(sigSLatchReg='1') then avSStateReg<="10000"; end if; when "10000"=> if(sigSLatchReg='1') then avSStateReg<="00000"; end if; when others => avSStateReg<="00000"; end case; end if; end if; end process; dfTrigSReg <= '1' when avSStateReg="10000" else '0'; process(CLK80) begin if (CLK80'event and CLK80='1') then if (sigCLatchReg='1') then avSigCReg(0)<= sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg; for I in 1 to 9 loop avSigCReg(I) <= avSigCReg(I-1)+ (sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg); end loop; end if; end if; end process; process(CLK80) begin if (CLK80'event and CLK80='1') then if (sigSLatchReg='1') then avSigSReg(0) <= sigSReg(13) & sigSReg(13) & sigSReg(13) & sigSReg(13) & sigSReg; for I in 1 to 9 loop avSigSReg(I) <= avSigSReg(I-1) + (sigSReg(13) & sigSReg(13) & sigSReg(13) & sigSReg(13) & sigSReg); end loop; end if; end if; Ws0<=avSigcReg(0);WS1<=avSigcReg(1);WS2<=avSigcReg(2);WS3<=avSigcReg(3);WS4<=avSigcReg(4); Ws5<=avSigcReg(5);WS6<=avSigcReg(6);WS7<=avSigcReg(7);WS8<=avSigcReg(8);WS9<=avSigcReg(9); end process; end Behavioral; I have simulate it, it looks like adding the ten value last received from the AD. The divider is not occured in this part of code(or just discarding). I wanted to know more about a shift register and an adder tree you have mentioned. Thanks for your reply. I'm a new learner so that I don't understand why this code is messy.
