9 years agoHow to know or test the delay time of each logic unit
I am making delay line to implement the TDC. I tried to use buffers to make the delay line and want to know the delay time of each buffer element. But when I use the TimeQuest to report the path dela...
9 years agoMy objective is to make a fine time measurement TDC with ps order, so the counter's resolution is not enough. But thanks for your answer, I will try other methods. May be the oscilloscope can be used.
