9 years agoHow to know or test the delay time of each logic unit
I am making delay line to implement the TDC. I tried to use buffers to make the delay line and want to know the delay time of each buffer element. But when I use the TimeQuest to report the path dela...
9 years agoThanks. I will check it later. If it is hard to know time delay by logic, do you know other ways to measure the delay time? I am making the TDC to measure the time duration of the signal. If I don't know the delay time of each unit, I can not calculate the time duration of the signal even if I know how many delay units a signal pass. Do you have other suggestions?
