10 years agoHow to interface my verilog code with FFT ip core
I'm working on an application that involves the FPGA to take in an analog signal through its onboard ADC and perform the FFT using the altera ip core.
So far, my understanding is the ip core generates a verilog module for just the FFT and I will have to instance it in my own code. First question: is that piece of understanding correct? The verilog file that the core generated looked like: // Generated using ACDS version 15.0 153 `timescale 1 ps / 1 ps module myFFT512 ( input wire clk, // clk.clk input wire reset_n, // rst.reset_n input wire sink_valid, // sink.sink_valid output wire sink_ready, // .sink_ready input wire [1:0] sink_error, // .sink_error input wire sink_sop, // .sink_sop input wire sink_eop, // .sink_eop input wire [31:0] sink_real, // .sink_real input wire [31:0] sink_imag, // .sink_imag input wire [9:0] fftpts_in, // .fftpts_in output wire source_valid, // source.source_valid input wire source_ready, // .source_ready output wire [1:0] source_error, // .source_error output wire source_sop, // .source_sop output wire source_eop, // .source_eop output wire [31:0] source_real, // .source_real output wire [31:0] source_imag, // .source_imag output wire [9:0] fftpts_out // .fftpts_out ); myFFT512_fft_ii_0 fft_ii_0 ( .clk (clk), // clk.clk .reset_n (reset_n), // rst.reset_n .sink_valid (sink_valid), // sink.sink_valid .sink_ready (sink_ready), // .sink_ready .sink_error (sink_error), // .sink_error .sink_sop (sink_sop), // .sink_sop .sink_eop (sink_eop), // .sink_eop .sink_real (sink_real), // .sink_real .sink_imag (sink_imag), // .sink_imag .fftpts_in (fftpts_in), // .fftpts_in .source_valid (source_valid), // source.source_valid .source_ready (source_ready), // .source_ready .source_error (source_error), // .source_error .source_sop (source_sop), // .source_sop .source_eop (source_eop), // .source_eop .source_real (source_real), // .source_real .source_imag (source_imag), // .source_imag .fftpts_out (fftpts_out) // .fftpts_out ); endmodule How do I instance that module in my own code? I do not recognize the syntax of ".fftpts_out (fftpts_out) " at all. Where can I read up on this?1 Reply
Instantiate the code by copy and pasting the second half of generated file (that you've included above) in your higher level module. Substitute, as necessary, the signal names in the parenthesis for signals available in your higher level module to make connections to/from the FFT module instance. 'myFFT512_fft_ii_0' will be the instance name.
Cheers, Alex
